12 ft Sea King 1984...my first boat/first fixer upper...
Toobs360
Alrighty guys and gals, here's some shots of what I've done so far to the inside with some marine carpeting, pull and hinges...
Toobs360
Re: 12 ft Sea King 1984...my first boat/first fixer upper...
I just purchased a 1959 10hp Evinrude....problem is I don't have a pressurized fuel tank/lines and am no where NEAR knowledgeable enough to convert it to a single line...can anyone help?? I'm dying to get her into the water for the first time. Thanks so much in advance!!
--Taylor
kfa4303
Banned
HI Toobs. No worries. You can just convert it to a modern single line set up. It's not too hard and there are lots of threads here that can walk you through it. Mikuni seems to be the brand of choice for fuel pumps, but I'm sure there are others as well. You should be able to get it right here at iboats. Try reading this thread it may help. Good luck. Keep us posted.
http://forums.iboats.com/showthread.php?t=494783&highlight=Fuel+Pump+conversion
Toobs360
UPDATE: She's starting to look perrrrty...
Finished carpeting remaining benches, sprayed a pre-coat of primer, then a mat black primer (next step will be lineX)
Let me know what you think/suggestions
kfa4303
Banned
Lookin' good! Lookin good! Any progress on the motor?
