86 Stratos Transom Repair using Seacast
Status
Not open for further replies.
Troy H TX
I just spent a considerable amount of time on the telephone with Sebina Unger the CEO of Seacast. What a great and helpfull personality. I am sure I will fly thru my first transom repair with no problems with her as a coach. Just a little background, I was not previously a bass boat kinda guy more on the pontoon boat side. Well a few weeks ago my father-in-law who I have upmost respect for passed away and left me his 86 Stratos. I told my father-in-law that I would take care of his boat and pass it on to his grandchildren one day. Well the first day on the lake was eventfull as the bilge filled like Niagra Falls. When we pulled the boat out of the water it was obvious the transom was shot and luckily the motor was still attached to the boat. I will document my build of the boat on here as we can all learn from each other's techniques. What may work for one may work better for someone else or not at all.
Troy H TX
Re: 86 Stratos Transom Repair using Seacast
5546962621
Woodonglass
Check out my signature for a thread on how to post your pics
Troy H TX
Thanks, I will eventually figure this out. I think posting pictures is harder then re-building a transom.
Troy H TX
Here are a couple of shots showing the damage. I made the decision to cut the fiberglass because it was basically broken all the way to the top. I ordered the fiberglass and it's about $100.00 to replace the bad section. Hopefully the glass will be in this weekend.
Woodonglass
Troy,
Not sure what is happening but Attachments still not working. Are your pics on your PC? How BIG are they?
Troy H TX
I think I have it figured out. Here are two pics, one showing the broken fiberglass with the cap removed and the other taken about 30 minutes later all cleaned out. Cool thing is I bought a chain saw and didn't have to use it. I guess the wife will get her trees trimmed this year.
ezmobee
Wow, well ordinarily I'd be like OMG you cut your transom skin! but in this case, you're right, it was pretty well worthless as is. I will be interested to see how you tackle this. So glad you didn't lose your motor! Welcome to the forum Troy.
Woodonglass
You can use a piece of waxed melamine to layout and fabricate a NEW Inner skin for your transom if you still plan on pouring a Seacast transom. You can use 1/4" pvc tubing for spacers when you install it. Works great. Archbuilder, another iBoater did it on his rebuild.
benjiebass
Hello Im new to this form I have a 1988 stratos 181pro bass boat,went fishing and hit somthing under the water may be a log,well it did a little damage to my transom.I took the plate off from the transon (Top) saw that the wood is in bad shape will need to replace it soon (transom) My boat looks like yours from the rear do you have any more photos I can look at? wont to see if seacast can help me? thanks
oops!
hi benji....
welcome to iboats.
if you just look at any of the posts on the main page of the forum......you will find all you are looking for.
the link in my sig also is a very detailed look at a full rebuild.
start your own thread in the restoration with pictures and we can help you to a successful rebuild !
oops!
the op has not been back for allmost a year.....
we are going to close this one.
Status
