Welcome Guest - Sign Up today
No announcement yet.
Removing Tuff-Coat (Bed Liner)
  • Removing Tuff-Coat (Bed Liner)
    Hello everyone...I've searched the forums and I can't find anything on this - so if I missed it I apologize! I have a 19' bay boat (guess what kind...) It's a great boat. The guy who had it before me took the carpet out and painted on this stuff called "Tuff Coat Non-Skid Coating" that you get at Bass Pro Shops. The guy didn't bother to remove the carpet adhesive... So, the coating is discoloring and actually peeling up in places. Is there an easy way to remove this stuff? I'd like to get it out and put gelcoat in, but it is not sticking in some places and is bonded very well in others. Thanks in advance for any advice.
    Re: Removing Tuff-Coat (Bed Liner)
    angle grinder 30 grit sanding disc , goggles, mask, long sleeves, change of clothes in the garage, you ain't getting the house. air compressor, with blow nozzle.
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    • #3
      Fans, and read up in here, you need to install cloth before installing slippery gelcoat.
      • #4
        Take some pictures too! Before and after
        • #5
          Use a brother in law and metal scraper. It might peel up in big sections if it is applied thick. It is not like Line X or other commercial liners. It is rolled on. It wont hurt to try if it is peeling up all ready.
          • #6
            Thanks for the replies! Was hoping for some magic solution you can spray on at night - when you wake up - poof, the stuff's gone... Oh well. I did manage to peel large peices off where it was applied thick (as dsibl wrote). There were some thin sections that required a scraper. I was worried about screwing up the fiberglass with the scraper... My plan - peel this crap off, scrape this crap off, use a carpet adhesive remover to get the glue out, then sand it. I have a buddy that will apply the gelcoat. Here are some pics. Any suggestions on the adhesive remover - I heard Goo Gone works...
            • #7
              Try acetone to remove the glue. Its cheap, and available anywhere from auto parts stores to Walmart in with the autobody fillers.
              Becareful, its flamable, vapors are heavier than air so they settle to the bottom of the boat and build up to explosive concentrations. Use a fan to keep vapor buildup away.
              I used degreaser to remove adhesive on a large section of aluminum once. Worked well, smelled pretty bad.
              sigpic 1985 Bayliner 1600 Capri Cuddy, 1965 MFG Niagara Custom. >> MFG Video<<. >> MFG Project<< >>Bayliner Hard Top Project<< >>Bayliner Repower Project<<
              • #8
                aint no easy way out here bud........the little elves we used to use to work on this stuff when we were sleepin.......they done gone went fishin !!!!!
                you need a carpet scraper to get the primary coat off....then follow tashasdaddys instructions ..........
                blood sweat and tears !
                The Hull Extension Thread
                great info on all aspects on boat building with detailed information.
                https://forums.iboats.com/showthread.php?t=234392
                IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
                IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
                November 29 2010 RIP
                • #9
                  td meant ....you aint getting IN the house......
