WillTheThri11
- Apr 25, 2019
- 17
Hi everyone. Long time lurker, first time poster here. There's a wealth of knowledge on this forum. I've watched most of the friscoboater vids, read the other 1989 Brendella resto thread (really bummed about the photobucket issue). read a number of WoodOnGlass and Oops! posts as well and there's a lot of great information there.
Well let's get down to it. I bought a 1989 Ski Brendella about 5 years ago with a 351W and about 500hrs on it and at the time I knew there were probably hull issues, but like many I wanted to have fun and mostly just ignored them as long as the boat was running and operating well...likely my second mistake (1st one was buying this boat i'm startin to think). The bottom side has some kind of paint coating on it that is now blistering up.
Well this year we had crazy rains here and my cover ripped and dumped a bunch of water on the floor. I got a new cover within a couple days, but it never dried out well and the carpet molded. Anyway, long story short when it got nice enough to remove the cover, i also realized i had a pretty soft section on the aft starboard floor. I decided to do some removal of the rotted out section and before long i was completely without a deck and realized that some things had been covered up and incorrectly repaired in the past. The stringers are/were made up of two 2x6s running from the stern 14 ft (of 19) with the section at the motor looking like it is double thickness but they're hollow in a bunch of places. Ther are no cross beams/bulkheads anywhere on the stringers. I ripped out just about all the foam so far and much of it was soaking wet. The foam job from the manufacturer was horrible and left multiple voids which had standing water in them. I found a section of the hull (3-4ft) which had been repaired...and the list goes on.
At this point i'm wondering if the hull is even worth keeping and putting a new deck and stringers in.
So main questions:
1. Is the hull worth keeping or should I consider parting it out? And if so, how much work do i need to do to the bare hull before even starting the stringer/deck job.
2. For the stringers, should I consider a seacast pour? Looks like that would be about $1000 in seacast, plus a bit more to cap them off with glass. Benefits I'm seeing to this are speed and time is money. Plus looking at all the resin and fabric prices, it might not be much difference in price anyway? This keeps all the motor mounts and everything right where they're at which reduces chances for mistakes in replacing them. I'd only need to grind the hull and stringers for tabbing the deck which would be much less grinding I'm thinking.
Link to all my photos can be found here:
https://photos.app.goo.gl/5NQoFVZ4AxbRjMSUA
I've put titles for most all the photos. I have a feeling the answer to #1 will either be chuck it or that i have to remove all the bottom paint and inspect further.
A little about me: I grew up working on my vw bus, working in a machine shop and building cabinets and doing other home construction jobs. I've welded two halves of a car together and I've glassed a surfboard. I don't have a garage or a shop anymore so this would be a driveway restoration, but I have a decently stocked tool shed and friends with some of the bigger equipment. All that to say that I'm not scared of taking on this task. I just want to be realistic on what I'm getting into because time is precious and I've got a lot of irons in the fire at the moment.
Your help and expertise is greatly appreciated! Thanks in advance!
So main questions:
