When I do transoms, floor repair even with marine grade wood I always coat it with resin you'll never have a problem again
Polyester resin has little to no value when used w out fiberglass, epoxy can be used w out fiberglass.
Not sure how you got confused, but no member can delete posts, only Moderators can. Squad did not delete your post. In fact the post you clsimed he deleted was never actually posted, an error on your end somewhere.
No one else but you and Squad posted here until this post, so again, not sure how you got confused and directed comments at some unknown 3rd party you referred to as a clown. That explains why Squad had to ask
In the future try to mind your manners, if you cant be helpful, avoid posting, and refrain from the name calling, esp when you're the one who's confused.
Also please refer to resin as either polyester, vinylester or epoxy resin, rather then simply resin . For new members working w fiberglass, it isnt helpful referring to it as resin.
Squad, apologies for the mess made overnight.
Good luck w your project
