Woodnaut
- Jul 4, 2007
- 634
Re: what kind of plywood is every one using
12 years ago I built my boat from mahogany, marine grade plywood (okoume) and (West System) epoxy resin. Actually, I completed the hull in 2000, but started on it a few years before then. The marine grade stuff and epoxy has worked very well for me. As has already been pointed out, it wasn't cheap, but I was interested in going for what I thought was the best.
The edges of plywood are particularly susceptible to moisture ingress. I learned that covering the face with fiberglass, and covering the edges with a trim board provides excellent protection. The following photo shows mahogany trim around the outside of the plywood. This transom (and the trim boards) is about 2" thick. The trim boards also give a level of protection against the inevitable dents and dings. Don't go cheap or light on the epoxy.
