Shadow66
- Feb 21, 2009
- 76
Have a 2002 3.0L Mercruiser Alpha 1 Gen II Sterndrive. I was browsing through some past posts and saw that some say you should always keep your outdrive trimmed down when running the engine at all. Is this true? Some said it was not necessary and downplayed it.
I called a dealer yesterday and asked and he sounded vague but leaned toward doing it saying it was hard on the drive shaft in the up position but mostly spoke of the "noise." I asked if it was just when the engine was running or if were engaged in gear only...he said whenever it it running only the prop shaft is not turning and everything else is engaged.
I have run it up quite a few times when on the muffs and it seems fine but I do not want to damage anything or wear anything out.
I already have made up my mind to lower from here on when the engine is on at all (not just engaged), unless I hear some evidence otherwise.
So what's the skinny on this?
