Well, I've just about got the carb back together, and now I'm moving on to the ignition system for a change of scenery. I've got it all torn apart and cleaned up; now I'm starting to put it back together.
I've got new plug wires installed, and new kill-switch wiring (I'm sure that's not the proper name for those wires, but that's where they go, so there you have it). Got new condenser #1 installed, and I've got breaker (point?) #1 on the armature plate....but now I'm a bit confused. Is there supposed to be a gap between the spring-loaded portion of the breaker/point thing and the mounting boss on which it sits? 'Cause I have no idea how to get a gap there; that spring is really pushing that little sucker against the boss tight.
Where, exactly, is the 0.020" gap supposed to be? I don't want to install anything else until I get that figured out so I don't have to work around unnecessary hardware to fix this. Thanks in advance.
