Air Natique had (as an option) a 230e back 2012 that was all electric...I just looked on their website and it's no longer offered as a model? I wonder if there's a market for this? I'm doubtful you did this at all as a business endeavor, but I wonder if you could consult with some boat company (Bayliner, Four Winns, Chaparral, etc..)
A quick search yielded this...
http://www.alliancewake.com/wake/the-super-air-nautique-230e/
Actually, I am thinking about this as a business venture. More along the line of providing a service to convert to electric vs partnering with a dealership or manufacturer. It is difficult to get the ear of the decision makers in these scenarios. If the individuals expectation with respect to range are reasonable, it's a pretty cool alternative. Thanks for the comments.
As a guy who owns a houseboat whose steel hull is riddled with holes caused by a small DC voltage leak-- yeah, I would keep it all in a glass boat...A hull that is an insulator vs a conductive hull Tough choice for an electric boat
I would argue that offering a conversion would be more costly and more challenging than starting from a 'shell' from one of the manufacturers and installing. I could be wrong (ask my wife). I would entertain an electric with the stats you've posted, but to convert from gasoline to electric would defeat the purpose of buying a new boat...Maybe work both angles...conversion for existing boats and as a factory option (with a warranty)? I know, opinions are like chocolate starfish...yada, yada, yada.
Hello I have to say this is the BEST / most PRO EV conversion I have seen
IMHO the performance specs you are getting I would picture a 16 or so side console/centre console "fishing machine"
that would run a few MILES out to the fishing spot and then a day fishing and then a return trip home
as for maintenance free I assume you are using the cooling system from the out drive to pump water to you water to OIL heat exchanger and the in LEG water impeller will still need replacement + LEG oil changes + I would assume the ATF oil + filter once a year
so you would "save" the tune up portion of annual maintenance and would NEED some sort of corrosion mitigation routine on all the wiring busses ETC
(NOT NITPICKING just pointing out)
The thread is to long for me to read all the way through so forgive me if I ask a question that has already been asked.
Why would you pick a brand new zero hour boat? why not a used boat off warrantee or even one with a blown motor or better yet buy a hull with no motor?
Very cool! Having picked up a used Chevy Volt this spring I can tell you electric is the way to go. The silent , buttery smooth, instant torque of electric drive is addicting in a car and I'm sure the same with a boat. I like to drive that car more for the way it drives than anything else. The efficiency is just icing on the cake.
Wow...one of the few that made it into consumers hands. What do you do when you need to get parts for it?Thanks! I have an all electric Coda car. I use it as my daily commuter and I'm spoiled by it
