lckstckn2smknbrls
- Sep 18, 2008
- 1,114
I've always heard motor torque will lift the starboard side of the boat. Having the driver weight on that side helps keep the boat running flat.
It's 66* and sunny out, so I'm heading out to go work on the boat. For some reason I've got a little spring in my step today. I haven't felt like this for, oh I'd have to say, about 8 years or so.
I hadn't really thought about trying that at all honestly. The plywood skin on this boat acts as an integrally stressed member once it's applied. True the fabric or fiberglass could pretty much do the same job, if the boat were just used for display that is. I've seen enough stuff floating around in the water (San Fran. bay had the WORST water I've ever seen ) to feel the need to have a hard shell skin that the plywood provides. If this boat was going to be a super lightweight folding boat type that I just rowed for propulsion, then I'd consider it. But it's definitely not going to be like that at all. This empty hull is likely to end up weighing in at quite a bit less than 500lbs and will have a 115HP motor pushing it along (IE: A very FAST little bugger). Fabric just doesn't have the built in safety factor that a plywood skin does for me to feel comfortable with it under those circumstances. Plywood can still get punctured if I hit something in the water at high speed, but it should still hold up way better than fabric and dope or a thin layer of FG in the same situation. I would think I would have a much better chance of making it back to shore with a plywood skin under those circumstances. Good point to think about though. Like I hinted at above, it would be a feasible alternative to plywood on a boat that fit those parameters (light and slow).
And there wasn't any boat work done today. I just got back from a VA Dr's appointment and it's already dark (and cold) out.
