WildBill79
- Feb 25, 2008
- 18
I have 1986 85 hp Force that will start up first try every time and run in a bucket in neutral but when I put it in gear in the water it has a terrible bog and usually dies when I give it throttle. If I am slow with the throttle it will usually start going, get on plane, and do about 30mph. A compression test was performed and it said there was 60psi on 2 cylinders and about 70 on the other. I did the compression test on a cold motor and warm motor with and without the throttle open and got the same results. Does this seem right? Where should I start? Thanks
