Hi everybody. I created a post last fall when I bought this boat and was met with some great information. Much thanks to everyone who helped.
With the warmer weather I've just begun working again on the Lone Star. This past weekend I removed all the hardware and began stripping the paint with Klean Strip. After some basic cleaning I started to inspect the wood in the transom. It seems that it is in great shape except for the top left and right corners where there were pieces of hardware (stern eyes). Both of these areas (about the size of wallet) are in bad shape and it seems to be impossible to remove the wood and install a new piece. It is secured on the bottom and sides and is covered on the top by the aluminum cover (blue) shown in the second picture. If I can removed the rotted areas is there anything I can use (epoxy, sealer, etc) to prevent any further damage? It doesn't seem that the aluminum transom cap can be removed, but I am welcome to anyone proving me wrong on this.
There are numerous holes, 1/4" or less, on the transom I'm guessing from underwater equipment that was used. After I remove the paint and clean it up, can these be patched with JB-weld and then sanded and painted? I've used it on virtually everything before, just not on an aluminum hull.
As far as the windshield goes, I was hoping to remove and disassemble it for cleaning and polishing. I can't seem to find a way to removed it though. Has anyone successfully accomplished this?
Thanks in advance everybody. Without these forums I'd be clueless.
