I am currently looking at a 1977 Bellboy that has an OMC 165, I was able to take it out on the water a few days ago briefly. It ended up cracking the plastic fitting on the forward part of the exhaust manifold used for cooling and we were towed back in. I have a few questions about some things that happened before the fitting broke. 1. It seems like it took a little while for the RPM's to build up after putting the throttle forward, is this normal. I am used to outboards and they respond immediately with throttle movement. 2. When initially put under load to accelerate there was a little pinging, it stopped when up to speed. I know this can be caused by numerous things, the boat had been in storage for 3 years and hadn't been out on the water, could this be bad gas and/or what else should I look for. 3. There was a little smoke coming out of the recirculation hose from valve cover to carb, after it was shutdown, is this normal for this year of boat. It doesn't smoke at all while running or start. Anything else you guys can think of I should check would be great. Thanks ahead of time.
