Okay I want to start off by saying I want to thank everyone for their input...I took the motor to a guy that knows Evinrudes...here is what he found out...there are 2 little tubes in each float bowl... those tube were filled with dried up oil or varished or something like that....he said he had put the float bowls in a special machine with some type of liquid that will shake the float bowls...he stated that carb cleaner was not going to unclog them...they were varied over to bad....that was my problem....so if someone has the same problem with their engine running good on muffs but bogging down in the water....thus could be your issue....
