hey ive got a 1994 vovlo penta 4.3gs holley 4 bbl and am having problems ..it runs good on the muffs but whe i take it on the water it stalls..the carb would flood in all 4 barrels i rebuilt the carb replaced the relay the p.o supposedly replaced the pump and seperator i went out this morn turn the key on no pump..bump the starter pump starts and stayed runnin without the engine running flooding all 4 barrels repeated this same process 3 times same results all 3 times..tap the relay it shuts offfrom what i understand the pump is supposed to run a few seconds when u turn the key on to prime then shut off..it is a autozone relay..other than a bad relay what could cause this...
