Hey all - I inhertited my dad's old 1978 Ranger 1850 Fish & Ski. It's been out of the water for the past few years and I'm trying to get it water worthy again. I've found lots of good info here already, but am stumped on an issue so I thought I'd make a post.
The engine will turn over, starter rolls the engine, but no spark. The last time it was started was probably 2 summers ago. Back then it had brand new plugs, wires, distributor cap, points, etc. Basically the Sierra tune-up kit. It started up pretty good but several of the gauges were flaky (batt, temp, fuel). I'm pretty sure the tach didn't work at the time either.
Now fast forward to this spring - tried starting it up and it won't start. The shift-kill switch checks out ok. I've also replaced the coil while trouble shooting - no change. Using a multi-meter from the +side of the coil to the possitive side of the battery and with the ignition OFF I get 12.5 volts - as expected. Turn the key to the RUN position and that voltage drops to 0.3 volts. Everything I've read says it should be at least 7.5 or 8 volts in that position. It has a resistor wire, but most issues with them or corroded connections drop it a little lower to say 5 volts. But I'm thinking i've got a short to ground somewhere since it's going to ~0.3 volts. The wiring back at the engine is pretty straight forward and nothing looks in too bad of shape. So then I started looking at a ground in the intrument panel because of the gauges acting up.
Next thought is that it might be a shorted tach. I've disconnected each of the three wires that go to it (+, tach, grnd) one at a time and it makes no difference. I also tried disconnecting the +bat wire that leads to the fuse block - thinking that that might cut one side of several of the gauges but I didn't see any change in voltage at the coil when the key was in RUN.
Any experience with a similar no-spark issue? Am I on the right track that it's a short? Any idea of the most common culprit or a way to rule things in or out?
Sorry for writing a book - but I've spent a lot of time on it already and wanted to give you details.
Thanks,
Thanks,
