tashasdaddy
- Nov 11, 2005
- 51,019
1988 50 Johnson, VRO eliminated. work on for a friend.
recent purchase, would not accelerate, would not idle long. so we did a carb cleaning, and kits, impeller, power pack was heating up and failing, new pack. it still will not take throttle, but will if you hit the primer, which leads to fuel pump, but at idle it acts like it is flooding out, cause the plugs are wet. sometimes when you hit the primer when starting it acts like it want to run away. in water and muffs.
i'm getting a rum and coke, and pondering over this one.
