Zodiac patch repairing
Beach King
What do is use to remove an old patch, glue and other adhesive goop material from my 10 ft soft bottom Zodiac model Series 1 ,S.131? Also can I use a one part glue to use as an adhesive for a new patch, or is the 2 part glue the better choice? This is my first inflatable and am unsure as to what to do. Thank you all in advance.
Gav
Re: Zodiac patch repairing
Use a hot air gun to gently but firmly remove the patch. Use two part Bostick 2402 applying two coats and applying patch ONLY when you can touch the glue without it sticking to your fingers. As applying the patch push excess air from top side. Leave the boat inflated for at least 24hrs.<br />Good luck
Beach King
thanks Gav, I'll give that a try. Thanks again.<br /><br />BeachKing
