OptsyEagle
- Sep 13, 2006
- 1,365
I noticed this thing on the cavitation plate of my motor. Wasn't sure what it was so I removed it and searched the part number and found out that it was a zinc anode. I am assuming that pretty much tells me that my motor was once used in salt water.
My question then is: is there any other use for these anodes and since I will be using it in fresh water, is it OK to remove them and do I need to do anything other than just unbolt them (repaint metal area that they covered, etc.)?
If my motor was used in salt water, is there any parts that I should look at closely to replace due to corrosion, etc. Right now I am in the process of figuring out why it has no spark.
