Re: Zert vs Buddy Bearing
Although I've never seen a failure, I've never liked the idea of the EZ-Lube or Spindle-Lube axles. I just have always felt safer with a solid axle.
I do like the simplicity of the EZ-Lube style axle but a bearing buddy is a bit easier to service at the ramp. I like to give the bearings a shot of fresh grease after pulling the boat just to make sure there's no water inside for the trim home, on a spindle lube, you have to fuss with the rubber plug in the dust cap, where as with a Bearing buddy you only have to remove a slip over vinyl dust cap. Each system has it's benefits and drawbacks I guess.
I have one older trailer that just has grease fittings in the dust cap itself, no bearing buddy or other system. To much grease on that one will push off the dust cap if you over do it.
