rhillman75
- Jul 28, 2010
- 176
To make it a very short story... we traded for a cruiser with a Mercruiser 5.7L engine. Any other time, any other season, I would not ask this but I did do the winterizing a little differently this year due to lack of time available. In years prior, I drained the block, re-installed the plugs, pulled the t-stat, and poured in the pink stuff. This year I actually only had time to go the storage yard with limited tools and lighting and proceeded in doing this... I removed all the drain plugs and and the large water hose from the pump and simply let it drain. I also cranked the boat up to the highest level to get the water out of the bilge. I then took the boat and trailer 15 miles away to have the trailer serviced. My question is... since I did move it 30 miles on a round trip, do you think with the motion of travel, all the water has been removed? I keep questioning myself enough to entertain the thought of making another trip to re-install the plugs and hoses and just filling it with the pink stuff. I know, I know, "air doesn't freeze", but how do you "KNOW" if all the water is out or there isn't enough residual left in it to damage the block?
