Re: Yet another 2+2 question
FP96,<br /><br />Yes, you are seeing it the wrong way. The mixture is so lean that it will not fire. Do the test yourself, pull the plug lead off either (or both if you really want to) of the bottom two cylinders and see that they are still firing. Not running on the bottom two cylinders is not wasting fuel, there is so little fuel there. It's done by leaning the idle mixture at the carbs, not by removing the spark.<br /><br />Chris...........<br /><br />P.S. You asked this question before and got the same reply.
