Yanking my motor - Help
NoSoup4U
Ive got some problems with my 2000 Four Winns 170 Horizen.<br /><br />I have a 4.3 Vortec 4.3 Volvo SX 190hp.<br /><br />I have removed, rebuilt and installed car engines, and my hardest by far was an 86 Fiero GT v-6, however I have never done a boat before.<br /><br />What manual(s) do I need? Which are the best? <br />Do I need special tools?<br />Anything else I need to know whould be helpful.<br /><br />I can't afford to have someone do this, and is why I am doing it myself. <br /><br />Also. Hoe can I get more performance out fo this motor? I heard I need manifolds that will flow before I do anything to the motor. Will it be worth it trying to make it go faster on a budget? Or should i just rebuild it to stock.
Re: Yanking my motor - Help
"can I get more performance out fo this motor?"<br /><br />Anything that can be done to a SBC,<br />Can be done to the 4.3l.....
motox6
motor is pretty straight foward to remove... remove outdrive (purchase aligment tool to get it back in once motor is in, remove ground wires in back of engine, remove wire harness (just like a car) and remove nuts and bolts off the engine mounts and walaa, done deal!!!
f_inscreenname
Do yourself a favor, before you take apart the motor to pull take some pictures. When you go to put the new motor back together you will know just how that bracket goes back on or where that wire goes.
NoSoup4U
"Anything that can be done to a SBC,<br />Can be done to the 4.3l....."<br /><br />Pardon me for sounding dumb, but wahts an SBC?<br /><br />What about manuals?
Fishermark
A SBC is a "small block Chevy" - a v-8 like a 305 (5 liter) or a 350 (5.7 liter). If I'm not mistaken a 4.3 liter engine is basically a 350 with two cylinders removed. The bore and stroke is the same.
NoSoup4U
Ah yes. I should have picked up on that. What about exhaust? I heard that doing anything to these motors doesn't matter becasue the factory exhaust limits flow. A boat tech told me I would have to get some after market exhaust manifols that let the motor flow more. Is this true? I can't find any after market manifolds for a 4.3. Is doing anything to it even worth it?
