i have a 4-stroke 4cylinder 50hp yamaha that idles rough. i have another of the same engine that does not have this problem. i have exchanged all attachments electrical and otherwise from one block to another and the problem (rough idle) persists. the following was done <br />compression checks - 210 psi on all cylinders<br />carburettors synchronised<br />power pack, plugs ok<br />checked ring gap ok, deglazed, and the # 3 cylinder still does not work. any ideas? thanks<br /><br />Brigs
