Rrosenbloom
- Feb 10, 2019
- 11
engine was running fine, then on the way in running at 4800 rpm, the alarm goes off. I immediately shut it down and let it sit for a few mins. Tried to start and it barely turned over, like the battery was low. Waited a few more mins and it started up normal. I was able to get back, but the motor struggled to get on plane (I’m prepared to be told that was dumb). Got home and changed motor oil, lower unit oil, checked for anything visually obvious. The lower unit oil was low, but no water in it. Test run next morning and I noticed the stream was weak. Got up to plane..still weak stream, then it slipped out of gear and revved way up, so I shut it down again. Restart was same as the previous. First attempt was like low battery - then started fine. Was able to idle back to the ramp no issues. Forward and reverse shifted fine, but stream weak and the motor just sounds a little off. Any ideas....I’m pretty novice at outboard wrenching? Thanks in advance!
