Yamaha XL760 New rectifier and lighting coil, still not charging. Help!!!
Yamaha 84
Hi everyone, Im a PWC noob and dont have much experience with the charging system found on it. I used the troubleshooting guide that I found here on iboats. https://forums.iboats.com/forum/gen...esting-a-yamaha-650-701-760-electrical-system
According to the guide, I should see 6-10 volts of cranking voltage from the lighting coil. I had around 3.5 so i changed it. The new one shows exactly the same. I put a new rectifier on and checked my grounds which all looked good, but still my battery is not charging.
Am I missing something or is there something else I should check? Thanks
