1993 Waverunner LX. I started the motor with the pump unit removed. It started normally and then died right away, which is not uncommon for it when it is cold. I cranked it over again and instead of starting it began backfiring through the exhaust. So bad that it blew my water box apart. I replaced the spark plugs, checked the index mark on the stator plate, and even put the CDI unit from my 1993 WRB700R in. None of this made any difference and it still will not start, it only backfires LOUDLY through the exhaust. Any suggestions? neil@hctc.com
