Yamaha water pick up tube advice
BDS05
Model C60TLRW.
I need to replace the water pick up tube (cracked) between the block and pump. Problem is, by looking at diagrams online I cannot find all the parts I'll need. From what I've gathered I will need to remove the power head. Can anyone help me out on exactly what all parts I'll encounter that will need to be replaced (gaskets, o rings, etc...)
good place to find a manual that's not 75$ for this motor?
Thank you in advance.
BDS05
I assume it could be repaired once removed but if I'm going through that I just assume replace it.
