Yamaha Trim Problem
cjg
Recently the Trim up stopped working from the remote (Yamaha 703)(Yamaha V6 150 1987 engine)but it works from the switch mounted on the engine.<br />Any ideas on how to check or fix<br />Thanks
Trent
Re: Yamaha Trim Problem
Take the switch out of the remote. Pull back the rubber cover on the back of the switch. Take apart switch and clean contacts.
Capt Ken
When you remove the switch and just before disassembling it, connect the red and blue wires together to see if the engine trims up. If so, then the problem is in the switch, if not, look for a problem in the wiring going back to the engine.
cjg
Thanks but I cannot seem to get the switch apart.<br />How do i go about it as I do not want to break anything :confused:
cjg
Sorry but I meant to say how do I get the switch out ??
cjg
The trim up will work now from the remote BUT ONLY when the motor is already 3/4 up from using the switch on the side of the motor<br />Any ideas ?? :confused:
