moderator1
- Dec 5, 2002
- 1,668
brentg <br />First Mate <br />Member # 33422 <br /><br /> posted September 25, 2003 01:41 PM <br />--------------------------------------------------------------------------------<br />I have a 1986 Yamaha 40 hp, the tilt trim also does not work, the motor for the trim does work but since i bought the boat I have had to manually pull up and down the motor in order to use the boat, from what I have read on this article, I therefore believe that I am also locked in the hydrolic system, is this true??<br /><br />I also have another problem I would like to ask you, my oil pump is locked in full which there for lockes the carburator in full throttle. Would you know why the oil pump is locked??<br /><br />brentg
