Re: Yamaha Tilt & Trim
Did you ever receive a reply ---- <br /><br />Here is my problem sounds like yours<br /><br />I tried to go out yestreday and could not get my motor to trim down. The motor trimed up once and would not trim down. There is a clicking noise in the engine (solenoid I think). To manually put the engine down I needed to releive pressure by using the relief screw. A few weeks back I noticed a leak on the floor, looked like tranny fluid could not find a leak, it only "leaked" once. I checked the fluid today and it looks fine but I am not sure if I checked it correctly. There is a screw in the housing between the 2 pistons. I open the screw and fluid came out. Not sure if this was the fill or drain screw. Could not find anything else. <br />Then in the afternoon I took the boat out in a local canal (not venturing far from the dock, Towing is expensive) and tried the trim while the motor was running. The trim motor spun but did not lift the engine. So now it could be electrical or low on fluid or something else??? Not sure what I have here but first I would like to bleed the system and try again.. How do you bleed the system to change all the fluid..Any help.... <br /><br />Probably need to take it in but want to check basics first. <br /><br />Also I live in North Broward any good repair shops recommended???
