Hello to all. I am hoping to get some help here and as it looks it is the right place to be. I have a 1992 85 h.p. Yamaha outboard. I am having to replace the trim motor. salt water finally had it for dinner! Question is How do I remove the assembly from the mounting brackets. It appears that I need to spread the mounting brackets a bit for it to come all the way out but am not sure how to go about it. I have a port-a-power to jack it open a little bit, but is the steering tube threaded all the way through to keep me from separating the brackets? One bolt snapped really easy and you know it had to be the one in the back so I couldn't get to it without removing the whole assembly. any guidance on how to completely remove the whole assembly would be greatly appreciated. It is close to coming out but needs just that little bit more room to remove.
Just in case, the model number is C85TLRQ
Thanks very much in advance
