Trying to wire the tach on a boat I just purchased. The tach was installed but not wired up. It is a 40hp Yamaha with side controls. (not sure on model #'s off hand, I can look them up if needed)
As you can see in the picture the tach has the wires for the lights (black and blue) and three wires for the analog tach. (black, green, yellow). The side throttle control has a few sets of pig tails coming out of it. One with the colors of the wires for the tilt/trim. The other with the wires i suspect to hook up the tach.(Red, White, Yellow, Green, Black) These are pictured in the second picture. I assumed it was as easy as matching up the colors but something isnt working.
Also there is a place to switch between 4, 6, 12 under a rubber grommet on the back of the tach. I have read this is to switch between poles. Any idea what setting I need to use?
Any guidance in the right direction is appreciated. I hate when something doesn't work right that seems so simple.
