I have a Yamaha Super Jet withe the following specs:
760 motor
no porting or polishing
billet girdle head 180 lbs compression
Riva single carb intake port match to carb
R&D Reed Spaces
U-Force Reeds
Hot Rods Crank
Wesco Piston (Stock Bore)
MSD Coil
Msd Ignition enhances
Lightened Flywheel
Factory B pipe with mod chamber
single 48 carb with air cleaner
What I am looking for is the Jetting Specs, Needle and seat size, and Pop off Pressure. If anyone could help it would be great. Just cant seem to be able to get it to run right.
760 motor
R&D Reed Spaces
U-Force Reeds
Hot Rods Crank
MSD Coil
Lightened Flywheel
