YAMAHA S250TXRX EFI OX66 Water mysteriously appears in the oil resevoir
OTTA B
Recently I overhauled my motor due to a melt down in the #2 piston. During the repair process I found water in my oil resevoir and water also in the oil pump (located on the motor). Consequently, I presumed that was the cause to everything (lack oil to #2 piston) including the rusted bearings ect. So emptied both the 2 gallon tank and the small tank located on the motor, replaced the oil pump & replaced the oil lines. After completing the overhaul, I began the break in process. After less than 10 hours the motor blew the #2 piston again. Soooo...I take the motor apart and what do I find? I find water in the line running from the oil pump and the resevoir located on the motor. And not just a little, it was about half of the line. I'M TOTALLY STUMPED,WHERE DID IT COME FROM? The contamination zone is so isolated and so small that it defies explanation.
I not only cleaned out the entire system during the overhaul, I also mad sure that I kept the TCW3 container in my pickup locked up and it was a new 5 gallon container. I wanted to make sure that no water got into the primary 2 gal resevoir tank. In other words, I presumed that my original problem was that I had somehow poured contaminated TCW3 into the tank to cause the problem. Knowing all this, how can anyone explain how the water can possibly get into the sytem?
robert graham
Re: YAMAHA S250TXRX EFI OX66 Water mysteriously appears in the oil resevoir
Well that's a mystery, and an expensive one, for sure. Hopefully one of the guru's here may shed some light on this, but I ain't the right guru for this one! I'll be very interested to learn how this happened. Good Luck!
