wes whitzel
- Apr 27, 2002
- 2
I have a 1986 yamaha 70 hp I was cruising along as normal and the motor suddenly reduced speed to half throttle I did not hear an alarm I checked the gas and gas line then shut down the motor and checked everything out everything seemed normal I started back up and it ran fine for about 10 minutes then it did the same thing I took it home and did a overheat sensor check as described in my repair manual it checked out O.K. I checked my alarm buzzer and it checked out also I do not have oil injection I have never replace the fuel pump diaphragm or rebuilt the carbs the motor actually has very few hours on it I have ran it for two years with no problems...I replaced the Impeller yesterday just in case and it did the same thing I would appreciate any help thanks Wes Whitzel ....UPDATE!! I replaced the fuel pump it still ran rough I let the engine warm up and then pulled the spark plugs and sprayed in Yamaha carbon solvent and let it sit for 15 minutes replaced plugs and started the motor up and sprayed the solvent into each carb for fifteen seconds each. I shut it back down and cleaned the spark plugs again as per directions on the can.after that it ran great. I am not sure what the problem was but the Yamaha magic solvent spray worked. I greatly appreciate the information obtained on this forum. Thank You...Wes Whitzel
