I use a Yamaha 50 DETO approx 1989 the motor starts and runs fine. After about 5 mins at maximum power the engine cuts down on revs to approx 2000rpm and will not increase. Selecting neutral will enable a higher engine speed but not when fwd is engaged. If I switch off and allow it to cool the engine perfoms normally again. There are no alarms sounding and there is plenty of oil in the tank. Engine does not seem over hot and plenty of water pressure at the pee hole. Thermostat seems to open ok in hot water and temp thermoswitch in the head operates at approx 95 deg.All plugs appear normal and identical. New water pump impeller recently fitted. Im stumped.
