Hey guys I have a 1999 225 OX66 that I am working on. The motor only runs at high idle (>1500 rpm) and is pushing to much fuel. The prop and grass around the motor is full of gas and oil.
Thus far, I have changed the O2 sensor (reads .8 volts), reset the TPS (.5 volts when throttle plate is completly closed) changes all fuel pumps (lift lumps and high pressure)and had all injectors cleaned and tested. The fuel pressure is 35 psi and cylinders all read 125.
Any other ideas? spark plugs are starting to get expensive. I do have another engine I could borrow parts from. I have used the injectors from it and it ran well unless you tried to get over 5000 rpms. As the engine is now, you cannot even get it into gear while in the water.
I do not know anything about the history of the motor. I got it in a non-running condition.
I am going to go get the injectors off the other motor and new spark plugs on Tuesday morning. If anyone has any ideas, I am more than happy to try those.
