Re: yamaha oil injection
Thanks for your help.<br /><br />That's what I was thinking so at the begining of the season I drained the tank and inspected the switch and it was moving freely. The pump turned off at the top, on at the middle and the buzzer was sounding at the bottom. Wouldn't the float switch be up at the top after I was done using the boat for the day. If it was sticking it should be in the top postion which is off and shouldn't be pumping at all ??? I was debating on just buying a new "gauge level switch" Does $150.00 bucks sound about right for a new yamaha replacement?<br /><br />Also could the manual override switch be malfuctioning?<br /><br />Thank you
