Re: Yamaha Multi-function guages
If you want the Yamaha digital gauges, you want the kit easygo0 mentioned above, the Yamaha p/n is 6YR-W0035-F0-00. You can also order it online from Central Florida Yamaha although it may take a week or two to get it if they don't have it in their immediate stock (yamahaoutboardparts.com).<br /><br />That kit comes with the extra wiring harness for the trim/tilt and the oil pressure warning that runs from the engine to the remote and the gauges. Most of the wiring is just plug & play but you'll need to splice in the (usually) pink and black wires from your fuel tank sensor to the speedo unit. I'm assuming you've got a 10-wire 703 remote, if you do it's not a difficult install. You'll also need to set 3 small switches on the back of the tach unit for a 2 lead trim sensor/12 pole tach sender/4 stroke engine. <br /><br />If the boat already has a pitot tube that runs from the dash to the outboard you can use that to connect to the speedo, but if it doesn't the kit includes a long length of tubing.
