Re: Yamaha Mechanic
Will having minor work and adjustments by a non certified mechanic void the warranty on my 07 f150 ? Thanks
All depends on what you mean by minor.
Like anything else you need to take stock of whats being done.
If it's an oil change then no. If they leave the plug loose or wrong oil filter and lose the oil and the motor seizes then yes.
Brake jobs. No. If you fill the Master Cyl. with something else besides the right fluid then YES.
Basically, if what you do results in a warranty able failure then it is voided because doing something wrong resulted in that failure.
