YAMAHA LOWER UNIT: OIL CAPACITY
madmike
HOW MUCH LOWER UNIT OIL SHOULD I EXPECT TO USE TO REFILL MY 1991 YAMAHA 115 AFTER IT IS DRAINED? IM DOING THIS AS PART OF MY WINTERIZATION PROCESS, WHICH I AM DOING 2-NITE. PLEASE HELP! I NEED TO KNOW HOW MUCH TO BUY. THANKS, MIKE
spete
Re: YAMAHA LOWER UNIT: OIL CAPACITY
I believe my '98 takes about 3 tubes, you may want to buy 4 just to be safe. After you fill, let it sit for 2 hours and go back and attempt to refill after bubbles and any air space has had a chance to work to the top. Also, you may want to replace the o-ring/gasket on the fill/drain screws just to be safe.
LubeDude
You might consider a Synthetic gear lube manufactured for marine aplications! Longer drain intervals, better corrosion protection and improved performance!<br /><br />LubeDude :D
rcmickey
I know this is an old post but I.m hoping you guys can help me. I have an 89 Yammy 90HP. I want to change the lower end lube but I only have one oil screw. Its labled oil level. My Johnson had two, one lower than the other, so you could pump it in the lower hole and the air comes out the top one. How do I get oil in their without air bubbles too?
bossee
Hi rcmickey,
According to Parts Catalog at Yamaha US website for Yamaha 90 hp 1989 it is screw nr 10 and nr 9 (to the front) for this purpuse, image 1 below.
http://www.yamaha-motor.com/outboard/parts/home.aspx
It is screw nr 1 and 2 in image 2 below.
/Bo
rcmickey
THNXXXXXX...........BOSSEE you are right on the money!!!!! :D I feel like an idiot for not finding it myself.:(
rcmickey
I replaced my lube but while I was pumping it in I could hear a click, clack sound. Click when I pumped then clack while raised the handle to pump again. Is this normal???
