Re: Yamaha Jet Boats
search around for some of my older posts on jet boats, I've got some long ones out there! Biggest piece of advice I can give you is don't take any advice from anyone that hasn't owned a modern jet boat. There are lots of 'i heard....' pieces of info out there, most don't apply to any jet boat that doesn't have a big block 454 on the back.
I'll leave it at this, there are very few jet boats in the used market, but lots of new sales. Owners that have a jet boat tend to love it and hang on to it. (seadoo is well over 1 million jetboats sold already)
**edit, tried to search and find some of my older posts, couldn't, so... here goes the summary version**
mpg's are going to be roughly comparable to a similar bowrider with the same type power plant. Jets have a long standing reputation of being gas hogs, but in the past i've posted side by side comparisons from boattest where similar length I/O's had worse mileage than jet boats. People tend to drive jet boats fairly hard, and anytime you drive a boat hard its going to suck down the gas.
As far as handling, a jet is a little bit of a challenge and there is a learning curve, but once you get it, a jet will easily out handle any prop boat. Especially with that twin engine, you will be able to do things that would require twin pods. Even with my single engine jet boat, i can spin in place, back up at any angle, or slide the boat straight sideways. My favorite maneuver is to pull into a double slip, and then rotate 180 degrees with about 3 inches to spare on each end. Once i'm facing out, I slide it straight over to the side and then tie it up. Been a while since I've driven a conventional boat, but I had my hands on a fairly large single prop I/O this weekend. I thought that thing handled horrible! Low speed handling was indistinct, everything was delayed, and it took lots of overreaction to get the thing to move. Its all a mater of what you are used to.
One big drawback is the wake... The hulls aren't design for a nice wake, and jet drives cause lots of turbulence and mush. I've boarded behind mine, as well as pulled tubers. It works, but isn't ideal. The other drawback is that jets don't like weeds. If you drive in areas that have lots of vegetation, you will be swimming occassionally to clean the intake grate. You would think the jet would work like a big salad shooter, but it doesn't.
