MKIV Surfer
- Apr 30, 2010
- 10
In reference to my last thread here, you can browse through the thread to get some background of the current condition:
http://forums.iboats.com/showthread.php?t=424302
Cliff Notes of the thread: Boat Vandalized, wires cut.......need to rewire.
Motor Info:
Year: 1986
Model - L200ETXJ
I was told to post the electrical questions from that thread in here and you guys could help me get up and running (well, at least get the wiring right).
As you can see from the other thread, only one of the motors were vandalized. And they cut all of the wires from underneath the console. So, I figured the game plan would be to go ahead and hook the ignition up again, so I can get one of the motors cranked. I figured I could get the ignition hooked up, so once I get the other motor put back together, it will be ready to try and fire.
Here are some pictures from the other thread so you can see what's going on:
Instruments:
Cut Wires coming out from hull:
Underneath Instruments:
Ignition:
I have been browsing around to see what parts I needed or if I need to buy a whole new ignition switch. As you can see in the picture labeled "Cut Wires coming out from hull"; that is all I have to work with. And as you can also see, the "Ignition" pictures is where they unplugged the coupler that fed into the ignition switch (and also the gauges). I was looking at some wiring diagrams to see if I can figure out what parts I need, but was unsuccessful.
Please let me know if you need any model numbers for anything, so you know what parts to tell me to get or what direction to go in.
Again, I appreciate the help and this site has been great.
Motor Info:
Year: 1986
Model - L200ETXJ
Instruments:
Ignition:
