I have a Yamaha 4.3 I/O that burned up the impeller on the seawater pump. I replaced the pump impeller and when testing it, were not getting any water to the pump. I took the inlet hose off and backflushed the hose with the garden hose and some rubber came out at the lower H2O pick up. Water flows the wrong way from pump to lower pickup but will not flow back up to the pump. Any ideas? I guess I need to plan to take the outdrive off, to check the hose from the lower unit through the transome. Any Ideas? Capt. Help! RP <><
