Re: Yamaha gas gauge wiring help
Hi guys,<br />I still have a problem with my sending unit.<br />I have the wiring all hooked up and I put 15 gallons of gas in a completely empty 62 gallon gas tank. My meter didn't move off empty. When I pulled my sending unit out of the gas tank and manually pulled up on the float, my guage went up, but not all the way to full.<br />I was wondering if this has something to do with the ground going through the yamaha harness ground wires and not getting enough resistance or if it should be grounded directly to the ground of my fuse block?<br />Do sending units go bad? and if so how? What would be symptoms of a bad sending unit?<br /><br />I also wonder if the rod on the float isn't too short to give an accurate reading?<br />I am going to check the resistance with an ohmmeter tomorrow but was hopeful somebody has some words of wisdom.<br /><br />Mike (still tired of running out of gas)
