Re: Yamaha f80 to f115
Thanks Triton, Currently my lund utilizes the factory Lund Tach speedo and fuel gauge. It has an Overheat light/ as well as an oil light for pressure. So the only thing the motor sends to the Dash currently is rpms,and killswitch function. The speedo is on water pressure via the little hose from the lower end to the dash, the fuel is a sending unit direct to the dash, and the overheat/oil pressure lights are obviously tied in as well. The current plug from the dash to the engine is a factory round style 8 or so pin connector that goes directly in the the engine. My thoughts are that the 80 and 115 are similar as far as plug configuration and maybe more info could be relayed to the dash like votage, and an actual oil pressure gauge, engine temp etc...Looks like they retrofitted the factory lund dash package to the yamaha harness and only needed the oil pressure/ engine temp light and tach. i guess worse case i get a different style engine plug if needed and add oil pressure gauges and a engine temp gauge if so desired. these are the controls I have. key and kill switch are factory lund in the dash
