Adding an Oil Pressure Gauge to my 16' Center Console with a 2010 Yamaha F40. Does anyone know where I can tap into the oil pressure system besides the oil pressure switch hole? There is not enough room to install a tee there so I need another location for the sender. Also does anyone know where I can get a 80psi oil pressure sender (240-33 ohms) with a built in low pressure switch that I could just replace the original oil pressure switch with? Thanks for any help.
