Yamaha f225 high temp alarm, Help!
rawtail
I have a 2002 yamaha f225 on my parker 2310. I have been having issues with the high temp alarm going off randomly for a couple of years now. It only happens when the motor is at low rpms 600-1000. I shut the motor off when the alarm sounds, it resets itself and is fine unless I continue to run the boat at a low rpm. I have changed the water pump multiple times, the housing, seals, impeller, etc. I just recently put new thermostats and a new poppit valve in as well and my high temp alarm went off again the other day while the motor was idling at 600 rpm's. Anyone have any ideas?
Thanks,
Lee
99yam40
Re: Yamaha f225 high temp alarm, Help!
It would be a good idea to replace stuff all at once, instead of over the years
we have no idea when you replaced water pump housing and impeller last
and have you tested the high temp sensors to make sure they are operating in spec?
Where and in what kind of conditions is this motor run?
Are you positive it is over heat alarm?
99yam40
Happy St. Pattys Day 99yam40
It is also my nephews birthday tomorrow, could you guess his name might be Patrick.
No green beer for me, but I am drinking some of the regular stuff right now.
Same to you Sparkie
rawtail
Thanks for the reply 99yam40. I have replaced the impeller every 200 hours on this motor, about every six months. I was reading through these on line forums and saw a few guys were having similar problems. So last week I changed both thermostats, the poppit valve as well as my impeller. I ran the boat the next day and had the alarm go off while the motor was in nuetral and at 600 rpms. On my electronic tac there is a flashing light that blinks on and off just above the temp icon. The alarm sounds as well. When the motor is at low rpm the pee stream is really weak, however at mid to high rpm the stream is really strong. I run the boat here in southern california running offshore 50-60 miles out and never have a problem. It is only when Im bounce balling for halibut or drift fishing with the motor running at low rpms that I have this problem.
Thanks again
99yam40
Either PRV is sticking open dumping water pressure at low RPM, or you have a leak in tube from pump,or the water pump is not pumping properly maybe due to housing not sealing are my guesses.
mpellet
Thanks,
Lee
I hate to be the bearer of bad news but what I will bet you are experiencing are issues related to major exhaust gas corrosion issues in the midsection of your engine. The Yamaha F225s, especially the 2005 and older model years are notorious for this. This is a wide spread issue and an expensive one. The low speed over heat alarms are one of the first symptom that manifest the problem . The oil pan sits atop the mid section and the potential exits for it to be involved in the corrosion mess as well. Parts alone for the "fix" used to be over $2000 but Yamaha has lowered the price on the parts to around $1100 , including oil pan and new oil pump (there is also an issue with oil pump leaks on the F225s, so while the power head is off it makes sense to replace the oil pump. The parts are relatively cheap for the oil pump. Labor from a Yamaha Dealer is gonna be roughly a grand give or take. The Power Head has to come off to do the fix.
I just went through this entire process this Winter and it absolutely sucks. Lots of threads over on the Hull Truth with pictures , just Google "Yamaha F225 Exhaust Corrosion" and you will find PLENTY of information that you don't wanna know. Here is a thread to get you started
http://www.redregulator.com/forum/showthread.php?t=442.
If you have changed out your water pumps, then you know dropping the lower unit is no big deal. Drop the lower and shine a flash light up the leg. This is not gonna be a 100% spot on diagnosis but my money says you will see a LOT of pitting and corrosion on what you can see, a bore scope inspection will likely give you more things to see you wish you had not.
I hope all the above is wrong but I'd wager and give odds ,your engine has the Yamaha F225 ROT.
I have the parts that came off my engine , pretty shocking how badly corroded some of them were.
Unfortunately fresh water flushing after use has absolutely zero effect on preventing this mess.
