Hi, I need help
My Yamaha F200xb 2014 was working fine until I changed the impeller in May 2018, the last time I used it was in March and the only time this year, when I left for the first time the engine started to heat up and the water jet by the exit it look like clog but was working fine before that. But when I flushed the water goes well. Then I changed the whole water pump (impeller, housing) but continued heated up. I checked the thermostat and it did not open well so I put a new one in it and I checked before to replace and was working fine it open at 158f temp. check the poppet valve and look good. Without the thermostat it does not heat up, and without the poppet valve and the thermostat set the water flow through the outlet improves but still warms up. Any suggestion.
